Phone Dash Mount
jonners_gti
Phone Dash Mount
im looking for a phone mount for my dash board, so i can make use of the sat nav on my phone etc. i don't want one that sticks to the window, i want something like this one:
http://www.dsldevelopments.com/SiteGFX/ ... 2689-4.jpg
this one however is only for cars with that line of buttons under the stereo, which the GTI obviously doesnt have.
you then click (or maybe bolt) this onto it:
http://www.dsldevelopments.com/SiteGFX/ ... 875156.jpg
anyone know anywhere to get something along these lines which will fit onto the gti? not managed to find anything as of yet.
thanks guys
thanks guys
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
I had one of these in the GTi:
http://www.dashmount.co.uk/vw/71449.htm
But I'd suggest one of these instead:
http://www.brodit.com/?main=productinfo ... anr=652832
jonners_gti
cheers Josh.
would it not be this one though, as the GTI has the cup and coin holders:
http://www.brodit.com/montering.jsp?anr=652689
was the dashmount one any good? it looks to be in a better position, the brodit one may get in the way if the cup holder opening.
thanks
thanks
jonners_gti
ordered one of these on saturday evening from dsl developments and it arrived today. just fitted it and its excellent! well positioned and easy to install. it doesnt get in the way of the cup holder either, which i kinda worried it might.
so if anyones looking for a phone dash mount i'd highly reccomend getting one of these Brodit ones.
jonners_gti
jonners_gti
sorry for the late reply...pics below
[img][img]http://img213.imageshack.us/img213/1369 ... tm0.th.jpg[/img][/img]
[img][img]http://img213.imageshack.us/img213/7965 ... jv0.th.jpg[/img][/img]
jonners_gti
jonners_gti
they do one for cars without the cupholder and coin holder. just make sure you get the right one! it should be item number 652832 on www.dsldevelopments.com that you need then.
Hey mate, I've got an N95 8GB with a copy of Sygic Drive. Just wanted to know if you had a similar phone and does it get a strong GPS signal being this low down in the car?jonners_gti wrote:they do one for cars without the cupholder and coin holder. just make sure you get the right one! it should be item number 652832 on www.dsldevelopments.com that you need then.
jonners_gti
Cheers mate. I was shopping last night at Tesco and stumbled upon a 'Universal Phone Cradle'. It was £4.97 so thought bugger it.....and it fits like a charm!jonners_gti wrote:Hi Dan
i too have an N95. I use the sat nav which is come pre installed (well it did on O2) and it works fine. Usually takes a few mins to get a GPS signal but works fine once its found it. I go into Tools and GPS data first, let it find a signal, then go onto the sat nav.
hope this helps.
Holds the phone well and fits perfectly into the centre air vent with very little movement going around corners
Very happy with my 'budget' purchase!
