Really Poor MPG on Polo Gt TDI?
hi guys,
My polo GT I have recently purchased has got really poor mpg, im only getting 250 miles to a full tank. My 2003 polo 1.9 tdi sport which is remapped was getting 370-380 miles on exactly the same commute to work. I know its cold outside but last week when I was driving the polo sport it was also cold and I still got 370-380.
Im not driving the GT any harder. Even the trip computer shows my average MPG as 27 which I think is rubbish.
Even when I brim the tank full the computer says my max fuel range is 290 miles?
The polo sport always states 400.
Is sometihng up with the polo gt? mileage is 34000 and it was serviced at vw two weeks ago
david burton
Slimbo9n
- Location: Rochdale nr Manchester Drives: 9n 1.9 tdi sport
hi pal i have the same problem with mine. ful tank im getting about 220 -250 and mines not a gt. i plug mine in at work and its got a coolent temp sensor fault so its tellin the car its cold when its not ie usein more fuel. there about 20 quid from vw. as soon as i do mine ill let u no if it changes. p.s this doesnt put the management light on so u dont no unless u plug it in
Definetely doesn't sound right to me either mate. I usually get about 50-52mpg average out of my GT, which is mostly motorway, which is around 380-420 miles to a tank.
When you say you are filling the tank, how much does it cost you roughly. When the fuel filler 'clicks off', do you vent the tank with the little button inside the hole, or do you stop then, cos I can get another £3 to £5 in by doing that?
i fill the tank completely. i wait for the click then vent the tank and then stick a few more poinds in.
The temperature gauge always sits at 90c when the car is warmed up. heaters work fine.
ive taken it to vw already once and they said cant seen any problems and low mpg is due to it being cold, but surely if its that cold the other polo should also suffer?
any ideas
any ideas
david burton
chris4500uk
madmatt
- Moderator
no dont do this it will do nothingchris4500uk wrote:Leave the battery disconnected for a few hours and see if you notice a difference, should reset the ECU
you need it plugged in to a diagnostic computer. i can garentie it will the temp sender .
basicaly its telling the ecu its cold and adjusting the fuel to suit.
if you have access to a diagnostic computer eg vag-com go to engine > measure blocks > 01 and it will tell the actual temp of the engine and then roughly compair with temp gauge on your clocks.
also check faults in engine . replace temp sender . and then delete faults
if you have any probs please feel free to pm me and if you not too far away i could sort it for you ..
cheers matt
madmatt
- Moderator
lol i worked at a main dealer i know how they operate lol bet they just scaned it and deleted faults becouse the mechanics wont earn money on jobs like that. thats what bonus systems do to this traderubber wrote:update:
was booked in at VW today, basically was told cant see any faults.
Must be my drivinig style, told them that used to regularly get 370miles to a tank on my other polo but they said the polo GT is fine.
david burton
