I am also put off by the extra noise. I think coilovers are a major factor in general noise. Bit of a pain in the arse. Lol.david burton wrote:I was going to get one of these, but the "trim noise" comment above has put me off for life!
A strut brace helps the tri m creaking, but the dash is still very noisy on occasion. anything that contributes is a big NO!
cubby box mod?
gary87
david burton
AKs_SlickPolo
Had mine for well over a year now. If anything it has reduced trim noise than the open type tray for me.
I did have the lid 'popping open' when I had Spax suspension on mine, But this has never happened to me when I had the standard suspension or even currently, where I have FK coilovers (which are much stiffer and a little more harsher than the Spax springs)
The cubby box just sits in the hole in the dash like the tray did - its the cubby box's lid hinge mechanism that eventually causes the extra rattling noises, like I think I said before, it could be that some white grease or something needs to be "replaced" fairly frequently. You usually find that if a part like this is put on the options list and does not eventually end up being fitted at the factory to the top-end models, then there is usually a good reason - like it might end up causing even more rattles. I fitted a Fischer casette box into a Fiesta dash once - and I can safely say that Ford would never have fitted it standard because it made a lot of noise.david burton wrote:it's odd, because I was thinking removing the tray and putting in the box might help (stiffer structure maybe). but clearly not. unless anyone wants to counter the argument?
