Hella Adapter Cable
Manni
Sponsor
Hella Adapter Cable
Post by Manni »
Anyone know a site that sells the hella adapter cable? The cables used to convert the 9n3 rear lights onto the 9n. Thanks
stig247
Post by stig247 »
you dont really need this, you can just change the wiring configeration yourself
DIY Guides » 9N3 rear lights on a 9N RHD cars
Manni
Sponsor
Post by Manni »
Yea, I tried, but i cant seem to get the pins out :cry:
ihpj
Post by ihpj »
I'm very tempted to do this MOD - but I'm not convinced the wires will all pull out (and re-thread) as easily as its made out. My worse case scenario is that I will shag one (or more) of the wires as I try to tease them out and screw the whole loom ;)
I would much prefer the adaptor (if there is one) or leave well alone! :P
creasegt
Post by creasegt »
go and have an ask in your local lucas/lsuk....i kno we deal alot in hella
Manni wrote:Yea, I tried, but i cant seem to get the pins out :cry:
Yes I sympathise with you on this - it sounds easy but unless you develop the correct knack and use suitably sized/shaped extract tools there is always the possibility of breaking the retainer on a few pins. I fitted a proper VW lane changer convenience kit on my Passat, it involved depopulating one connector and populating a new one - and it certainly tried my patience - in the past at work I've dealt with quite a lot of high density connector pin extraction/refitting.
