changing front sidelight bulb
Mitch_9n
Post by Mitch_9n »
ive just had a look as one of mine has blown. How the hell are you meant to get at it?
chris 9n
Post by chris 9n »
skinny fingers :lol: it pulls out
dino
Sponsor
Post by dino »
You'll feel the back has two little grips that you need to squeeze together slightly and pull back.
Tim_GTi
Post Whore
Post by Tim_GTi »
you should try getting them out on a mark5 GTi!
ihpj
Post by ihpj »
I think the size of engine also has a bearing as when I replaced the factory carp headlamps (H7 and H1) with Osram Silver Star bulbs it wasn't all that bad. Enough space to get my hand in and remove the bulbs with pretty much ease.
Took me about 8 MINS. all in as, admittedly, it was a bit fiddly.
Mothers car is a 1.4 16v.
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh it definately depends on the size on the engine
pip_polo
Post by pip_polo »
it's impossible to take out the headlight bulb on drivers side without moving the diesel filter, engion coolant and some random black box. thats on a 1.4tdi btw.
so i'm guessing petrols don't have diesel filters so easier :P
gary87
Post by gary87 »
I was able to change mine without taking off the fuel filter, if you just loosen it you can manoevure [sp] around it. Took me about 35 mins to fit mine in the fuckin rain.
pip_polo
Post by pip_polo »
gary87 wrote:I was able to change mine without taking off the fuel filter, if you just loosen it you can manoevure [sp] around it. Took me about 35 mins to fit mine in the fuckin rain.
are you mr stretch?
TimGti
Drives: 9n3 1.9 Tdi Sport
Post by TimGti »
Both my main headlight bulbs decided to blow at the same time before xmas.
It was getting dark and I was at work so I got the nice AA man to come a sort it :oops: :wink: ... Seriously lame, but much easier than trying to figure out how to do it in the dark!
Got to get my moneys worth from the AA somewhere!
