Polo GTi - FAQ - Common Modifications and Advice
Tim_GTi
Post Whore
Post by Tim_GTi »
Headlamp Protectors, Pressed plates and plates surrounds?
again, nice work 8)
MaxZ
Post by MaxZ »
Added number plates, any information about the headlamp protectors/where to buy them?
Si_GTi
Moderator
Post by Si_GTi »
The headlamp protectors can be bought from the dealers, they are about £32. Can be fitted in less than two minutes, they're dead simple to be honest!
Stickied this for you MaxZ :)
Tim_GTi
Post Whore
Post by Tim_GTi »
yep, also can be found on eBay for around half the price, and can pop on and off when required if necessary
frankeygsxr1000
Post by frankeygsxr1000 »
Thanks alot bud really useful post for newbie like myself...
Definatley need the red grill trim just looks so nice a project for this afternoon me thinks once again cheers dude
DannyMk5
Post by DannyMk5 »
Wicked thread max, well done :D
Trottagti
Post by Trottagti »
This forum is wiked, that is a wiked sticky and well bloody brilliant! Top notch old son!!
Tigz
Re: Polo GTi - FAQ - Common Modifications and Advice
Post by Tigz »
Lovely post :)
alexperkins
Site Admin
Post by alexperkins »
Headlight Dipped H7
Headlight Main H1
Headlight sidelight W5W
Indicator PY21W
Side indicator WY5W
Interior 42mm 242 11W
Boot 39mm 239 5W
Numberplate 39mm 239 5W
Brake/Indicator/Reverse Light/Fog Light P21
Some more useful bits!
PD
Post by PD »
RE: Cruise control.
On the GTi is it really just a case of a MK4 Golf stalk and VAG-COM to enable it on the ECU? I've read of people fitting this to Lupo GTi's and there seems to be additional cabling to connect to the ECU. Is it really as simple as stated in the original post?
MalakianCigaro
Post by MalakianCigaro »
I was wondering if somebody could point me in the direction of some pics of taking the rear VW badge off taking it apart and spraying the center body colour, I'm sure i've seen a step by step somewhere, I have searched and as of yet haven't found anything. Any help would be appreciated.
Thanks.
Leon
Tim_GTi
Post Whore
Post by Tim_GTi »
MalakianCigaro wrote:I was wondering if somebody could point me in the direction of some pics of taking the rear VW badge off taking it apart and spraying the center body colour, I'm sure i've seen a step by step somewhere, I have searched and as of yet haven't found anything. Any help would be appreciated.
Thanks.
Leon
Dead easy man, just pry it off, then cut the plastic tabs on the rear that keep the badge together.
Once the badge is off you'll understand exactly what to do.
Then just glue them back together. I used a glue gun for this, and B&Q foam tape to stick the badge back to the car.
MalakianCigaro
Thanks very much for the reply, I will give it a go.
myfastpologti
Post by myfastpologti »
This is an awesome guide, very informative!
Trunkz
Post by Trunkz »
PD wrote:RE: Cruise control.
Its not really THAT simple. Yes you need a mk4 golf stalk, which then needs to be wired (well.. soldered) to the ECU. Then its a case of threading this all back into the car, and plugged up into the stalk. Then a simple vagcom procedure. Awesome GTI still do this for £160. (Cant remember if that inc. VAT or not)
