Indicator Stalks/ Cruise Control
Hamish
Post by Hamish »
Right. The trip computer switch is a bit sticky so im thinking of replacing the RHS indicator stalk.
Looked in Haynes cant see the answer unless im looking under the wrong section :?
Is tis fairly easy job to do or is it steering wheel off etc etc. A method or any hints and tips would be very usefull.
Also. Are the LHS and RHS stalk units individual or are they one unit as im thinking about retro fitting cruise control 8)
dino
Sponsor
Post by dino »
Both stalks are individual and cruise can be retro fitted (just done it on my Golf)
It is a steering wheel off job to do though.
Hamish
Post by Hamish »
Thats ghey :(. Cheers for the reply though
Jeff GTi
Post by Jeff GTi »
is cruise just a plug and play stalk then or does it need setting up with vagcom or similar then?
i assume the process for the 9n and 9n3 would be the same
Hamish
Post by Hamish »
i believe that it takes some setting up on VAGcom
theres a guide here for a Skoda but you need to login
http://www.vagweb.co.uk/forums/about577 ... 845546718b
daa709
Post by daa709 »
Anyone feel like copying that guide over? 8)
dino
Sponsor
Post by dino »
I needed an extra loom on the Golf and it does need activating in VAG-COM
Hamish
Post by Hamish »
do you know if all models have it on the ecu its just a case of it hasnt been activated?
dino
Sponsor
Post by dino »
Im sure they do as they are all drive by wire (but dont hold me to it!!)
