Passenger side window
Prabz
Post by Prabz »
Ok guys got in the car today and started it up, tried putting passenger window down and it just makes a clicking noise, windows doesnt come down. The driver side is fine, checked passenger window if it stuck but its not, anyone know why ?
Si_GTi
Moderator
Post by Si_GTi »
Does it do the same thing no matter which switch you use - the one on the passenger side or the one on the driver's side - if it doesn't matter which switch you press, and it still doesn't go down, it could be the motor? The clicking noise would suggest that the switches are still working.
neilGTI
Post by neilGTI »
I agree with Si, its probably the motor, it should be easy to test if you take the door card off.
Prabz
Post by Prabz »
Well on passenger side it clicks same with driver side, the windows just don't want to come down, thought it was motor
neilGTI
Post by neilGTI »
If it is clicking on both switches but nothing is happening, its 95% likely to be the motor.
Try checking all the fuses & *relays first as it could be something simple ?
Also try taking your battery off for about ten minutes then re-connect it to see if that might help.
* I am not sure if the windows use relays, but this could be what is clicking when you press the switches and they do pack up sometimes.
TheEggShell
Post by TheEggShell »
Lol...
I've had exactly the same problem recently.
As you say, it doesn't matter which switch you press and there is a clicking noise.
Strangely, mine started working again (after removing half the door to look at the motor :roll: ) so finger crossed yours does the same!
