From what I've heard they don't make a massive difference in performance, but they look the balls
My GTI progress thread (Update 31st Mar - For Sale!)
Mouse_GTI
If there isn't a noticable improvement after 300 miles I'll be slightly worried. Driven over 20 cars but my GTI has the worst brakes I've ever used. What could be the problem if there if the new discs/pads don't make a difference in the future? Changing rear discs and pads/brake fluid last year made no improvement
- Tim_GTi
- Post Whore
I know, I hate it when you get glitches like this!MaxZ wrote:How are there 2 extra pages of this thread?
Mouse: Have you considered braided hoses?
mk4 glx 1.6
All you need is an 11mm spanner for the brake hose connection (the same as the bleed nipple nut that you should have bled the brakes with?).Mouse_GTI wrote:I have G60 calipers to be fitted by the garage when it goes in for it's MOT (we didn't have the tools to disconnect the weird connector thing on the brake hose)
G60 calipers are exactly the same, why change??
I hope you gave your coilover threads a good clean, they look like they could do with it!
mk4 glx 1.6
It depends on the disc manufacturer as to which way the discs should rotate, it should be detailed on the literature included but contrary to what most people believe, it doesn't directly relate to the grooves on the disc face.
Hopefully this helps:
I would bleed the brake system completely with new fluid (something like ATE super blue) before even contemplating braided hoses.
Why change your calipers though? They are the same type (Lucas 54). Unless you have any issues with your current calipers. Having just had to replace a caliper myself (due to a seized piston) it is better the devil you know IMO.It is a popular misconception that the grooves or drillings on a disc determine the direction of rotation. In truth, for an internally vented disc, the geometry of the vanes dictates the direction of rotation. There are three vane types in use:
Straight
Pillar vane (comprised of many small posts)
Curved vane
The first two vane types are non-directional, and can be used on either side of the vehicle. The curved vane disc, however, is directional. A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation. The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc. This greatly enhances the disc's ability to dissipate heat.
Mouse_GTI
Just looked back through my whole thread for the first time in ages. Can't believe I thought that rear black badge (non colour-coded) looked good
The VW plates are terrible - ironically they are currently back on the car at the moment due to the cops making me get shot of the German plates. Wanted to put my original dealer ones back on but they are too scruffy. Any places that make plain UK plates with a tiny tiny postcode on them or nothing at all?
