help!!!
randomage
help!!!
Post by randomage »
this morning, i was reversing down a hill, and all of a sudden my brakes became rather ineffective and the brake fluid light started flashing with a beeping noise. the result was me rolling gently backwards into a car. i got home (it happened leaving my girlfriends) and checked brakefluid levels, and all was fine. the beeping stopped as soon as i was moving forwards again.
also, my speedo was flippign a little as well. the needle would drop suddenly and then go back up to where it was meant to be. i hadnt adjusted my speed.
any ideas? if its expensive to fix i need to know quickly... :(
alexperkins
Site Admin
Post by alexperkins »
Sounds like you either have a sensor issue, or an ECU fault has developed. It really needs to be plugged into VAGCOM for a diagnostic to check nothing serious is up and determine the cause of the issues you are experiencing.
NOZ
Post by NOZ »
As Alex mentioned get diagnostics done and I wouldn't deem it safe to drive if thats just happened either :shock:
randomage
Post by randomage »
its strange, it happened saturday morning and its been faultless ever since. ill have to get it checked over asap.
sylvester
Post by sylvester »
Not sure of your cars age, has it got abs, check the fuses on top of the battery as they can have corrosion on the terminals, possibly f5 and f6.
randomage
Post by randomage »
no abs, its a basic s reg 1.0, but ill check for corrosion anyway, just in case thats a problem.
sylvester
Post by sylvester »
Was the engine running ok when you were reversing?
randomage
Post by randomage »
yeah fine, first fault ive been worried about on this car, the only other problem is that both windows are buggered (common with 6n) and a large dent/scratch down the right side (my fault :D my driveway is a swine to negotiate)
