Is the Lupo GTI AVY exactly the same as the Polo GTI AVY engine - air con etc etc ?
If i have a Lupo GTI AVY engine and Gearbox, does it use the same mounting points in on the chassis ?
I know the lupo is 6speed and hydraulic clutch - but thats not so much of a problem to change the pedal box etc over...
Main thing i need to know is if i have a lupo gti engine + box will it fit straight into the exisiting points on my polo gti !
Cheers!
Lupo GTI Engine AVY
Glasgow, but i have access to a garage that my mate runs. It was just to see if i would be able to do it over a weekend - engine box out - new engine box in without any change !tegwin wrote:I believe the answer is no...
But it wouldnt take much to get it to fit....fabricate some adapters, perhaps weld them inplace....jobs a goodun!
Whereabouts are you located?
I thought it was just the polo gti engine didnt fit the lupo gti box (diffrent holes/bolts) , was uncertain if lupo gti engine and box - was just a straight bolt in job !
LOL, the short term plan is get the lupo engine & box in and working, long term would be to get more power from it!tegwin wrote:I may be wrong...stranger things have happened.....
Would deffinately be a nice conversion to make...
Lupo GTI engine with 6 speed gearbox, add a supercharger and jobs a goodun...
If I had more space in my garage I would offer to do the conversion and supercharge LOL!
This has been discussed to death!..
The lupo box is NOT a straight swap for the polo one..
The bell housing mounts are different, as is the gearbox mounting point...
Also the lupo has a hydraulic clutch (not an issue but something worth considering)...
I dont know if you could fabricate an adaptor plate to mate the polo engine with the lupo box..
If anyone has a spare lupo 6sp box im happy to give it a try
