Cold Starts Problem
TheEggShell
Cold Starts Problem
Post by TheEggShell »
Hi all,
I'm wondering if any of you guys have had the same problem or know what is causing this...
Basically, when I start my car in the morning it drives fine for a few minutes, then the engine either cuts out or stutters and then limits the engine to 5000 revs.
I turn the engine off and on again and then everything is fine for the rest of the journey.
Any ideas what the problem is?
TheEggShell
Ok,
I took it to a local garage who plugged it into their computer to discover that it has got a faulty RPM sensor.
Does anyone know how much these RPM sensors are?
Also, is this the same sensor as the camshaft sensor as I had that replaced about 3 months ago?
