[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 rear door speakers - UK-POLOS.NET - THE VW Polo Forum
currently got a 2001 polo 5 door which only has speakers in the drivers and passenger side doors, wondering if anyone has undertaken the task of installing two more in the rear doors and how hard it is to be done?
Getting Alpine type R's in the front soon and thinking about putting the standard ones in the back doors until ive got some more money for another set of Aplines..
MaxDub wrote:currently got a 2001 polo 5 door which only has speakers in the drivers and passenger side doors, wondering if anyone has undertaken the task of installing two more in the rear doors and how hard it is to be done?
Any input would be greatly appreciated..
Once i free from debt, ill be be doing this but i have a 3dr so it'll be more simple id guess.
Andy1.6 wrote:I want to do this too nd Im ready but I cant seem to get the door cards off without damaging them!
It means removing the rear seats which tbh aint that hard either, id never stripped the inside out before but me n my bro done it in 40min
MaxDub wrote:Have you done it then josh?
You have a 3dr yes?
I take it the back seats wouldnt need to come out in a 5dr or am i mistaken?
I have a 3 doord and nah i havnt done it yet, but my mate has a 3 doors golf and done it, aint that hard...
Erm as for 5doors,nah i cant see why the seat would need to come out, the only reason they would on the 3dr is for the rear door card,to cut the circle.
Yeh to get speakers in the back, either buy differnt doorcards, or just cut into your existing ones.
To get the rear doorcards off a 6N2, you just have to remove the two bolts under the grab handle cover, and the last remaining bolt under the window winder cover, then gently pull around the edges til all the clips pop off.
Yep that does, there's simply two terminals already available in the wiring kit you got with the headunit, just run speaker wire from the speakers all the way to them.
I haven't got time to find a picture of the where to connect them right now, I'll PM you it tomorrow though if you remind me!
how am i going to get the wire from the headunit to my rear doors? up the B-Pillars? in the end i coudnt even wire my front speakers as i couldnt get it into the door so i used the existing cable for the stock speakers
On the 6N2, you remove the rubber trim around the edges of the doors and remove the plastic card on the B pillar and doorcard. And it's just a case of feeding the wire through the exposed hole.
