someone else's answer not mine, can't take credit for it!
check it !!!!! turn 2 of he lights on for a few mins then turn one of the 2 off go in the room one is on and that is the switch you left on ....one bulb would be hot from you leaving it on that is the switch you turned off and the other one is the one you didnt touch atall !!!!!!!!
h4r1s wrote:someone else's answer not mine, can't take credit for it!
