Polo / Dials
vwp6n
Polo / Dials
Post by vwp6n »
Hello my mate is wondering if you are able to put lupo/polo gti dials into a polo 6n ? if so what would you have to do to fit them ?
thanks .
polo-sib
Post by polo-sib »
If the dial layout is identical then yes, you would do similarly to this:
http://babelfish.altavista.com/babelfis ... l_1998.htm
vwp6n
Post by vwp6n »
Okay Thanks been a big help :)
vwp6n
Post by vwp6n »
Does anyone if they are the same layout ? :?
polo-sib
Post by polo-sib »
When you say dial, do you mean that bit of paper with the numpers on showing your speed or the whole unit altogether?
If your on about the paper with the speed etc, the lupo one is completely different to the 6n. If your on about the unit as a whole theres a chance it might fit, but I'm not sure, also you'd have issues if your on about the unit as a whole. As a separate unit will have a different milage and you could get into some trouble if reselling etc. You'd have to get the milage tweaked to what your old odometer said.
vwp6n
Post by vwp6n »
He has changed his mind on that now . But he is wondering where you will be able to get the paper bit at the back
adam_0612
Post by adam_0612 »
ebay?
vwp6n
Post by vwp6n »
We have looked on ebay but there is none that look good .Does anyone know anywhere else that sells them ?
