Im looking for some drilled & vented brakes, any suggestions where to get them from and any recomendations??
Drilled Brakes???
- Tim_GTi
- Post Whore
I've heard black diamond are good.
http://www.venommotorsport.com/manufact ... gory=Brake
You could also get your existing ones done if you wanted.
I've done about 12k miles on a set of these from ebay although it doesnt say on the listing the discs are actually made by Lockheed (well at least mine were) and I've been well happy with them not bad at all for £70.
As for pads I chose Ferodo DS Performance which are superb albeit a little bit squeaky sometimes.
![Image](http://www.voutsy.pwp.blueyonder.co.uk/smallDSC00306.jpg)
Hi there,LiverpoloGTi wrote:I've done about 12k miles on a set of these from ebay although it doesnt say on the listing the discs are actually made by Lockheed (well at least mine were) and I've been well happy with them not bad at all for £70.
Check the link you posted what fitment did you use for the polo also did you get rear disc as well.
Thanks.
