How to remove door cards?
jazzy639
Post by jazzy639 »
Hello
Does anyone have a guide, preferably with pictures on how to remove the door cards in a MK6 9n Polo?
If it matters, its a 3 door and has manual windows so the electrics on the drivers door is just the central locking and wingmirrors.
chewy
Post by chewy »
you have 4 screws along the bottom of the panel and two under the door handel, the winder might pull off or it will have a clip on the back of it. then pull the panel off fron the bottom its held in place with 7 clips, when its loose lift upwards and disconnect the cable and the two wire connectors. Hope this helps.
jazzy639
Post by jazzy639 »
Thanks very much. Will give it a try over the weekend hopefully.
