starter motor help urgent
1der
Post by 1der »
Whats the best way to free of the starter motor guys? Nedd to get it sorted so i can get home tomoro from work
tegwin
Post by tegwin »
Piece of wood threaded in from above the starter motor behind the throttle body and a stonking grea thammer...
Give the bugger a good few taps where it meets the gearbox.,..
I take it you mean that its spinning but not engaging? Rather than being jammed?
If its spinning but not engaging you proberably have a bent spiral shaft....not good!
1der
Post by 1der »
the car will bump start and got it home today
When i turn the kry there is no click, and also a connector to the solonoid has cracked off
tegwin
Post by tegwin »
Sounds like you need a new starter motor in that case!
1der
Post by 1der »
it was just the connector going onto the solinoid above the starter that was the problem. it had cracked of
