gemmiella wrote:would 5% make that much difference?
I have 195/50/15 on my 6n polo and i think it looks really good.
If you get 45s on the front there might not be as much rubbing issues if your not planning on altering the arches, my 50's rubbed a bit on the plastic arch cover so i just took it off and im no worse. depends if you like flaps or not haha =p
thats only my opinion, dont have to listen to me =p
x
195/50's rub like f**k, secondly your speed is taken from the front wheels and ratio'd from the gearbox using
standard wheel size and the 50 profile causes a error as its quite abit bigger than the standard wheel size, try explaining that to a cop when he pulls you doing 75 mph and your speedo says 70 or when a camera flashes? It'd be like
"yea my tires are incorrectly sized so I can go faster" sure that will go down well with a fine and points as I've been there done that.
Part from that I am still going to go for the 50 rear and 45 front look yosin
, think it might add some downforce, but don't know how handling will be effected and whether it'd increase wheel bearing wear as the car will be slanted? So I'm hoping someone else has done this for advice.
