Had this light come on last night, after driving around most of the day. Car seems to drive/sound fine, so I'm not quite sure there is a problem.
I did a search and came across a thread saying I should be filling up with 98 RON petrol - oops, didn't know that. Could this be the cause or is it something?
I'm going to Sheffield tonight for the weekend (about a 2 hour drive) will I be ok to drive?
I've had that light on for over 2 months now!, every now and again it goes off for a short while. I've got so used to seeing the light the dash looks weird when it's not illuminated.
Oh yeah and the car sailed through its MOT emissions test with the light on. Drives just as it always has done and mpg doesnt appear to have suffered, so im not too concerned about it at all.
Mines doing the exact same thing has been for around 6 weeks, been into VW and they said its the lamda sensor. It triggered five faults-something like, running rich, low on performance, low on oxyen etc. All related to the one sensor, it's about £200 i think and i'll be getting mine booked in shortly. As said its fine to drive unless the light starts flashing and just dont rag your car.
£200 you should be able to get a universal one for less than 50 notes, the job is a doddle, think they are a 17mm ring spanner disconnect old wiring and cut, remove old sensor, fit new sensor, resolder wiring from new sensor to old loom and job done, the light should clear itself...
02 sensor 4sure!
get one from german and swed they sell the same ones as vw think there around the 20-30 pound mark!
o and dont let anyone charge u more than 20 quid 2 fit it! (its a ten min job on a ramp!!!)
