195This is the width of the tyre in mm. Looking at the tyre from above or from a forward view.
45The ratio of the height of the tyre (profile). A percentage of the width. 45% of 195mm is 87.75mm
15The wheel diameter in inches.
78Load Index. Weight in which the tyre can withstand. Measured in Kg the number's are set by a table which will tell you the capacity of the tyre
VSpeed rating of the tyre. The letter is set by a table which will tell you the speed rating of that spacific letter.
Load Index
Speed Raiting
