Hi guys,
Just copying this head from the engines/powertrains section - just after a quickish response and I know less people check the sections lower down the list
Anyway, here goes:
Long time since I've been on uk-polos
I'm having some troubles changing the clutch on my polo - it's a 6n 1.4 8v, 99/T reg. Everything under the bonnet seems roughly the same as on my old mk2 1.05, which I successfully changed the clutch on - it was an awkward job, but I got there in the end. However, with the mk4 I've got as far as trying to refit the gearbox and there just seems no way that it's going to go back on. After a few hours of trying I've worked out how to lift it into position to mate up to the clutch and the engine block, but it simply won't join up with the clutch assembly. Is there some kind of knack to it, or am I overlooking something? Any help much appreciated!
