2 x FK 10mm spacers 5x100 + 8 x 10mm longer bolts = £40 inc delivery (only 8 blots as I had a locking bolt on each wheel)
Used condition. Can split etc...
Tim
pm or email to [email protected]
They slide onto the centre part of the hub and you bolt the wheel through the spacer into the hub using the longer bolts.polospeed wrote:do these go between the wheel and the hub or do you bolt them to the hub then the wheel to the spacer?
Yep, still got them. Strictly speaking, yes you need 'equivalent' longer bolts for all spacers to retain the same thread going into the hub, but you could run them if your happy with 5mm less thread into the hub?Wardy wrote:You still got these? Interested in both sets.
Are longer bolts required for the 5mm ones?
Cheers,
Steve
Normally companies on ebay do them, they are not much (like £1.15 each or something) depending on length. Oh yeah, G-werks and AMD do them aswell.Wardy wrote:Yeah, OK - that's what I thought. Have you a recommendation of where to pickup the bolts from?
Also, did you buy longer locking wheel bolts as well? Just wonder if these would be available, if you're going to something with a 4x100?
Cheers,
Steve
