Camber setting
ticki
Sponsor
Camber setting
Post by ticki »
Does anybody know a good camber angle setting for Polo GTi? Obviously im looking for improved steering response and grip.
Ian_R
Post by Ian_R »
You can only adjust the camber at the front, and even then this is very very minimal! So you won't notice a difference at all TBH,
Just make sure the car gets set up correctly for the height that your putting it. If lowered then you will notice a camber at the back, but this CAN NOT be changed as it's a solid beam, BEst thing to do would be to throw an ARB on to it to stiffen it up and so it will become tail happy - Thus enabling you to corner better than if it is to understeer!
ticki
Sponsor
Post by ticki »
thanks. Fitting new wishbone bushes i need my camber a tracking redone. When i first had my coilovers on they where set pretty high. I then turned them down 40mm. Which would naturally create a negative camber, and trust me it dones make a difference to the steering. It feels tighter and more positive.
