6N Alarm fitting help
e.data.tech
Post by e.data.tech »
I been installing an alarm in my MK4 6n polo and needed so help on some of the connections.
Can anyone tell me which wires in the car are for the following and where they are located?
- Side door positive trigger
- Side door negative trigger
- Hand Break
The alarm also has an engine cut off relay. Does anyone what I should connect this to?
On the installation diagram there is a connection called Start sensing what is this and where do I connect it?
I can supply an installation diagram if needed
scottyj12
Post by scottyj12 »
i put one on my 6n the other week. Haveyou got a wiring diagram. I may beable to help
e.data.tech
This is the diagram sorry about the bad quality spent a while tring scan an A2 page on an A4 scanner
scottyj12
Post by scottyj12 »
Hmmm sorry i cant reli help! mine didnt conect to any door triggers!
