Suspension!!!!!
POLOZ
Suspension!!!!!
Post by POLOZ »
Hello Fellow Polo owners......have a question......
Since the wishbones were changed on my polo, the driver side suspension has been making a rather strange squeaky noise.......sounds as if there is a mouse under the wheel arches...... :lol:
It only seems to happen when it goes through bumps or any depression on the road......its fine over speed bumps.....
So any suggestions will be appreciated....
KJ
POLOZ
Post by POLOZ »
Any body???? :D
david burton
Post by david burton »
Stick some grease on your springs, oil it up, and then get back to us - it could be one of many things I'm afraid.
Mike
Post by Mike »
need to ask a few questions, why were they changed by whom and did they use grease in the bushes?
POLOZ
Post by POLOZ »
The bushes were changed by VW.....themselves as the bushes had play in them.....all was done under warrenty......
POLOZ
Post by POLOZ »
david burton wrote:Stick some grease on your springs, oil it up, and then get back to us - it could be one of many things I'm afraid.
david mate....the springs are brand new eibach ones...only had them two weeks....
I am suspecting the shocks.....how do i oil the front shocks? :?
I'd get the car back to your VW garage - there should not be any noises - as long as your springs are the right length - did VW quiz/warn you about using these springs when they replaced the (TCA ?) bushes - or was it only the ARB bushes they replaced?
On the other hand, if there is a mouse under the wheel arch liner, I'd give it some cheese and then tell it to f--- off and annoy someone else - that usually works!
POLOZ
Post by POLOZ »
RUM4MO wrote:I'd get the car back to your VW garage - there should not be any noises - as long as your springs are the right length - did VW quiz/warn you about using these springs when they replaced the (TCA ?) bushes - or was it only the ARB bushes they replaced?
:lol: .....
Well mate when the bushes were changed the car was on normal springs....even though it was making noises after the change...i thought it might settle down after a week which it didn't...and i forgot about it and got the eibach springs on it without realising to get it checked before....as far as i know the wishbone bushes were only changed...according to dealers
Only problem is that my suspension and the components are no longer covered under the warrenty as it got void after got the eibachs on her....
so dunno how to approach them.....
POLOZ
Post by POLOZ »
Bump....Any more Ideas.... :)
POLOZ
Post by POLOZ »
Guys it been a while since i posted this thread.......
Well the problem still exists and its bloody anoying the hell out of me.... :x :cry:
The problem is that since i changed the standard springs to eibach lowering springs....i have been told that it would have an affect on my warrenty.....so i havent taken it back to the dealers....as i am sure they would know the problems then and their that is....springs are the fault....... :oops:
Neways would you's all recommend to get it checked with dealers anyway.... :?:
KJ
david burton
yeah, take it to VW and see if they can diagnose it for free.
alanred
Post by alanred »
Anti-Roll Bar ?
I've not heard a single squeek since i had mine done.
POLOZ
Post by POLOZ »
alanred wrote:Anti-Roll Bar ?
Pm'd you.....
Is there a way i could check the antiroll bar bushes for wear and tear?
