Rightclick KE60W Remote Central locking onto a POLO 9N3 PICS
Dezmoand
Post by Dezmoand »
The blue/white wire is located in the loom behind the plastic panel where the bonnet release is for my 9n1. You may need to remove this plastic panel and undo the loom tape covering the wires. This is the locking wire which the remote locking control unit sends a negative pulse through. If you hook it up to this wire, it will enable the deadlocks as if it locked with the key - might even allow you to roll up and down the window depending on whether holding the locking/unlocking button on the fob prolongs the negative pulse.
chinnus
Post by chinnus »
still havnt managed to do this yet.... there must be someone else out there who is struggling as well if anyone has done it or has any ideas could they please share? thanks in advance x
MGrove03
Post by MGrove03 »
think im goin to invest in this sometime this month so ill let ya know how i get on :wink:
chinnus
Post by chinnus »
where abouts do you live in the uk i cld post you mine to borrow and try to figure it out?? to save you wasting your ££ if you cant manage it i have tried everything..... elsawin diagrams and all
chinnus
Re: Rightclick KE60W Remote Central locking onto a POLO 9N3 PICS
Post by chinnus »
sorry to bump an old post but has anyone found a solution to this?
thanks again
tom
