The GTI! - Alex's Thread - Leather :D
alexperkins
Site Admin
Post by alexperkins »
Gonna order the short shifter soon me thinks...little bit of fun!!
Fixed the passenger side electric window tonight. It was the same as the drivers side.
Basically the glass mount pops off the runners, so the glass goes up at an angle, which stresses the motor.
The fix is as follows....
Get a headboard mount washer:
And a tap washer
And a screw:
...i cant find an appropriately sized picture!!
Take all the doorcard, door lining, and window guide out (all in the haynes manual!)
Basically, you get the broken mount, put it on the window guide as it should go.
You then put the headboard mount over it, and push the hole over the mount center. You then put a tap washer in between, and a nice wide screw in to hole it all tight.
Tighten it up and voila your window is fixed for about 50p!
As for the motor, take the top cover off, and smother it in white grease - this will stop it seizing. Also take the metal plate out the motor, and also smother this in grease:)
At the end you have a good as new electric window!!
Overseer
Post by Overseer »
Alex, how easy is it to replace the microswitch for the boot lock?
I need to replace mine as washer fluid got on it a fooked it. Still got it unplugged at the moment, but I fancy having it working again.
alexperkins
Site Admin
Dead easy. Take off the rear boot panel (two T20 torx screws)
Undo the boot latch (its a 6mm allen key)
It pulls forward. Unplug the connector, and pop the locking rod off
Then you just pull the microswitch forward out of the case - so if you had the latch on a table, it pulls upwards!
Then just pop the new one in, refit in reverse, and voila fixed :)
alexperkins
Site Admin
UPDATE:
Short shifter ordered :D
MaxZ
Post by MaxZ »
Someone has too much money!
alexperkins
Site Admin
Someone thinks someone else is right about that!
tomo87
Post by tomo87 »
MaxZ wrote:Someone has too much money!
i think the word is daddy :lol:
alexperkins
Site Admin
UPDATE:
Fitted the new headlight washer and i can safely say its not leaking anymore :)
Also fitted the new boot microswitch - seems you can clean them with just a bit of wet and dry if you didnt want to buy a new one!
But anyway, i now know when my boot is open :)
Polo96CL
Post by Polo96CL »
Good progress alex, i'm eagely awaiting the new pictures. Get your arse into gear!
No pun intended :D
alexperkins
Site Admin
Wooo short shifter tomorrow!!
In other news, im in wales for a few days now, so I am going to be getting some photos with Tim, and then i will finally get them online!!!
Tim_GTi
Post Whore
Post by Tim_GTi »
After seeing this car in the person, and giving it a quick spin, I can say that it is veryyyy nice 8) coming along beautifully Alex.
It's really not as fast as mine though :lol:
alexperkins
Site Admin
Its much faster dammit!!
Tim_GTi
Post Whore
Post by Tim_GTi »
Next available quarter mile strip, we'll settle it fair and square 8)
tomo87
Post by tomo87 »
its red...there for the slowest of the GTI's.....silver used to be fastest but i have now decided black is fastest
Trottagti
Post by Trottagti »
All the paint and repairs i rekon it must weigh alot more lol! Must be slower than mine! ha!
