hi sorry again but iwas just looking at the spacers and i saw a description of it that it makes it wider if you get me and then another bit said that the distance between the wheel arch and tyree...
Yeah the main reason you will fit spacers is so the wheel fills the arch better, look here http://www.tigerstyle.co.uk/poloforum/v ... 72e150b50c page 4 pip has fitted some 20mm spacers and you can se how the wheel looks alot better from behind. To find out what size spaces you can go up to you woould need to fit the wheel then measure from the wheel to the arch leaving some room, normally between 10-20mm spacers would be the ones of choise.
