vw polo foglights..
yosin
vw polo foglights..
Post by yosin »
Pickin up my polo on tuesday but the 1 of the foglights is shattered so i need to replace.
I also need to replace the driver side side lights.
Just wondering is it a straight foward job or does the bumper need to come off.
For the foglight is it just the case of taking off the grille and undo screws?
3LL1077
Post by 3LL1077 »
Replace side light or headlamp?
Either way you will have to remove your bumper mate, someone will be able to link you to the guide on here
And with your fogs its a simple undo the screw holding the cover on and swap the units over
yosin
Post by yosin »
i c ic...the fogs is the worse off...i think i might go searching on the DIY but then..
however if some knows how without taking off bumper please shed some lights. thanks...Or if its like doing it on the 6n mk4?
yosin
Post by yosin »
Side light not the headlamp btw sorry.
3LL1077
Post by 3LL1077 »
Bepe
Post by Bepe »
there is a way to change sidelights without taking the bumper off
tegwin
Post by tegwin »
Balderdash.....You DONT need to take the bumper off to change a sidelight bulb!!!!
You need to remove the battery if its on the nearside, or the air intake pipe if its on the offside....then its possible to get to the back of the lights....Its a fiddle....I used a mirror and head torch to do mine.....patience and its doable...
As for the foglight....if you remove the engine under-tray you can get pretty good access to the back of the fogs....I recon doing an exchange would be possible...
Tom W
Post by Tom W »
tegwin wrote:Balderdash.....You DONT need to take the bumper off to change a sidelight bulb!!!!
Quite true, took me about 20 - 30 mins to do the sidelights dont know what all the fuss is about :)
As tegwin says i think if you jack the car right up so you can get underneath and take the undertray out you should be able to replace the foglight from there without taking the bumper off
Tom
yosin
Post by yosin »
thanks alot guyz ....just that i need to change this stuff when i pick up my gti on Tues :D...
ticki
Sponsor
Post by ticki »
I need one of these also :cry:
alexperkins
Site Admin
Post by alexperkins »
The foglight can be replaced by just removing the grille, and the three screws that hold them in - there is no need for jacking, undertray removal, or bumper removal to do this.
yosin
Post by yosin »
ahh even better then :D...
thought it might be possible to do this way when looking at the 1 of the side light replacement diy guides from somewhere on here.
Just cant wait till tuesday now :(
ticki
Sponsor
Post by ticki »
look at my DIY guide, for sidelight replacement
http://www.tigerstyle.co.uk/poloforum/v ... =sidelight
yosin
Post by yosin »
By the way do you mean i can change the whole foglight housing not just the bulb?
alexperkins
Site Admin
Yes. If you wish to change the bulb, remove the foglight, then unclip the back and replace the bulb.
