Whats the difference?
- KennyPOLO_Gti
- Platinum Member
Whats the main differences between the 1.8T 150bhp and 225bhp engine?
- whitegtipolo
- KennyPOLO_Gti
- Platinum Member
piston size is the same as the engines both have the same bore, 1781cc
and no, they are no stronger, they use all but the same blocks
rhumor has it, bam engine codes are more likely to fail at 330 bhp than 150 bhp engine codes, as for some reason, the 150 unit is stronger, but how true this is i cannot say
- whitegtipolo
this site will tell you all you need to know www.vag20v.net
