[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Tyre Stretch - UK-POLOS.NET - THE VW Polo Forum
195/50s will send out the speedo. It should be 195/45s on a 6-7inch rim for accuracy
Stretched tyres can be dangerous depending on the stretch...basically if you go round a corner too fast, the tyre can flex so much itll seperate from the rim - not good!
Exactly. 7s you could do a 165/50/15 if you want some serious stretch. My RH Cups came on that...it looked good...but i had to get rid of it as i just didnt feel safe!
