Clean engine bays??
jamie1.8tpologti
shantybeater
shiming the rear beam is somthing you can do 2 alter the camber setting on the rear 2 put it back 2 standard settings (before you lowered it) or even improve on the factory setting!
It has 2 be done with shims because the rear beam isnt adjustable on the polo's!
nobody seem's 2 do it much on vw's (think cos people are more intrested in show than go) but people who tune other makes fords' pug's (more intrested in go than show) its a very cheep and easy way or making a massive difference 2 handaling!
If your intrested i can get the shims made up by the same place that made mine!
shantybeater
- Tim_GTi
- Post Whore
To achieve that you'd have to take the engine out, smooth the bay and relocate alot of things, including hiding all the wiring.
Camber shims ain't hard to come across, here's some:
http://www.edition38.com/forums/index.p ... pic=170138
yer there the ones tim!
maby vw people do do it aswell then!
only thought they dint as mine is the only one ive seen done andd ive worked on afew of them !
yer that pic is excatly what i want!
been thinking about how i can do it and ive come up with answers for most bits!
Battery and washer bottle relocated 2 the boot!
Get a rad made with a expansion tank built into the top! (like most cars)
just leaves p/s bottle and wiring ! which im sure i can come up with somthing!
been out on the car all day 2day (well inbetween doing pj's as they turned up) and ive think ive figured out were every thing is going 2 live!
Just got 2 head down 2 my metal man with the drawings ive done and get some custom pots and tanks made up and order a battery relocation kit and ill get cracking!
[/quote]
