May seem a silly question but is there anybody with a Polo 16v (or GTI) who has had it a while NOT had a gearbox problem?
Been thinking about getting a mk4 Polo to replace my sick mk3 GT and am a little concerened about the gearbox problems I keep reading about.
Do they always break? I don't want to buy a cheap banger and then have to spend nearly a grand fixing the gearbox!!! I do a lot of town driving so the gears get used a lot.
Polo 16v's gearboxes
BeezerDiesel
Polo gearboxes in general aren't too great but problems occur more in 16v's and 6n2 GTI's because they're the models that put most strain no the gearboxes to show them up! They tend to get starved of oil or something (can't remember the cause but was told ages ago!) and the bearings usually break.
Anyway, if you thrash the gearbox like crazy then you could cause it to break. However it shouldn't cost anything more to recon then £600. SO the best thing to do if you have concerns is to put rally bearings inside your good box before it breaks! It will be much stronger and cheaper then fixing a broken one.
BeezerDiesel
