[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 car bouncing - UK-POLOS.NET - THE VW Polo Forum
1der wrote:
if i go round a corner and hit a bump it throws the car and unsteadies it. is this due to my coilovers?
Sounds like you dont have enough damping... can you adjust the rebound on your coilovers?
Having said that... if your springs are too hard regardless of damping you could be getting axle tramp.... but you would need fairly hefty springs.... or big bumps to do that!
Coil on the right this has collapsed and all the pil out it. So this is how it will look if any of yours are like that, the one on the right is fine, just the fact i think FK are pish, and they rust far to easy and all the paint flakes away of the springs.
Not sure on your's TBH, could be a number of things, if a leaking coil you would here them knock like f**k going over bumps. my one certainly did.
Sounds like its purely just the set up. Mine has always done this and there isnt a thing wrong with mine. Its purely down to the dampening and the ride height.
To be totally honest, go for another brand Coilover, like KW or weitec...much better overall than FK in regards to performance and build
It is possible that the camber at the back (and to a lesser extent, the front) is badly out due to the fact you are quite low.... That would also give a bouncing sensation as you go around corners.. Camber wedges would sort that one....
front camber should be okay tegwin as was done a fortnight ago. the back is quite low. perhaps im best trying the wedges before considering new coilovers?
