Question about UK/European (Area 2) DVDs
Non-VW related chat - Moderated
Babe RuthLess
Post by Babe RuthLess »
Folks,
a friend of mine is flying to Europe in a few days' time and he's thinking about buying some hard-to-find-in-Brasil DVDs in the UK, France and Italy (including some for yours truly).
Question is, will they work over here?
I know the discs have those "area" lock codes (we're Area 4: South America, Australia, NZ). However, most DVD players in Brazil can be unlocked for the equivalent of a tenner or so (well mine was anyway) so I'm not worrying about that.
I've been running Area 1 (USA/Canada) DVDs from Amazon.com without any problems.
But I remember that TVs, VCRs and even Super Nintendos and game packs from Europe wouldn't work here, the TV systems being completely incompatible although they share at least part of their names (PAL in Europe and PAL-M in Brazil). Something to do with our PAL system running at 30 frames/sec and Europe's at 25 frames/sec. So North American VHS tapes for example would be viewable here (albeit in black and white and with loss of picture quality) but European ones would only show a blinking mess accompanied by loud bursts of noise.
Will DVDs suffer from the same problem? Does anyone know about this?
Thanks for your replies,
Carlos
rooboy
Post by rooboy »
A lot of the UK DVDs are also classed as region 4 (to save on production cost with Australian versions), so there may not be too many problems. When it comes to the Pal format, quite a few players over here will give you the choice to play the DVD in either PAL or NTSC no matter what system the DVD is formatted for so if it is the same in Brazil you may be in luck.
The only way to find out for sure is to buy just the one and try it. If it works, them use uk DVD websites such as www.play.com (or the portugese equivelant for the language barrier) and get them sent to you by airmail.
Tahrey1043
Post by Tahrey1043 »
PAL at 30fps? Cor that's a bit bizzare (though I know for one thing, that's what my bro's chipped Playstation-1 puts out when you run an NTSC game in it)... suppose that's 525 lines as well?
Ahem. Yes. Well, if it doesn't have much trouble with American titles you may just be in luck with ours. So long as your machine is able to work with other-standard DVDs (it's probably internally configured as NTSC, just with a modified PAL output - all in the encoding in this case, rather than the lines/fps) it will hopefully have some kind of converter in it. Unlike video tapes, the DVD doesn't store the signal encoding natively on the disc, just the picture information and the player does the rest of the work, so it's a whole lot easier to implement.
EG My own video and DVD player. The VHS machine was a fairly expensive late-90s machine, it chokes dead on anything that isn't PAL. But the DVD player, I bought in 2001, it was the cheapest model available at the time, and it will play damn near anything except for some heavily customised videoCDs. So long as you put in the "secret" unlock code (eject-2468-eject :roll: ) it will play any disc from around the world, even with that "CSS" stuff, and will convert a PAL disc to NTSC standard and NTSC to PAL. It looks a little jerky sometimes because it has to try and fit 25 frames into the space of 30 (which works ok 90% of the time) or 30 into 25 (...not so good), and the picture can seem a bit "off" (as 576 lines have to squeeze into 480 - a bit like hardware conversion of a widescreen movie onto a regular set - and 480 stretch to 576) - but is watchable in the end once you're used to it. Not really any worse than what NTSC folks have to put up with for TV movies (24fps stretching to 30fps, whereas for PAL you just speed it up 4% and it fits perfectly :D). You can even choose what output you like on it, it doesn't seem to have any particular "zone" preprogrammed into it, apart from it knowing it's technically a Region 2 machine.
(And then, it all comes down to what your TV will accept - if you're in luck, your player will be able to put out "PAL M" at 25 as well as 30 frames, and your TV will accept it, which will make everything a lot smoother and look a lot better (there'll be the right number of lines, too)... most modern systems are multi-mode as the circuitry to do more than one standard costs pennies, versus the higher cost of making whole different versions for different countries - they can make something that will do any standard so long as it fits through a PAL-M filter.... or even include two cheap filters... and then it just auto senses what signal is coming in and sets itself accordingly)
Technical enough for you? :D
Basically: If they haven't yet left Brasil, and their DVD player accepts Super/VideoCDs (or DVDR) and they have a CD(/DVD) writer.... make up a test disc to UK standards (352x288, or 352/480/704/720x576, at 25/50fps, with PAL encoding of course!) and see what their system makes of it! (any video clips you can find, so long as you have a suitable encoder and CD/DVD burner.. if you have a technical head, try TMPGEnc and VCDEasy... if not, a copy of Nero will do it all for you)
Lalala
Babe RuthLess
Cheers Rooboy and Tahrey1043!
Tahrey, I suppose yours is as good an answer as I'm likely to get without actually trying the DVDs.
The idea of PAL running at 30fps is strange I know - then again, Brazil is a strange country. It turns out that back in the '60s we had to figure a way to make the PAL colour system (which I understand is superior to NTSC) work in a country that used 60Hz AC mains... Thus PAL-M was born. And yes, it's got 525 lines (check http://www.ee.surrey.ac.uk/Contrib/WorldTV/compare.html for other details).
Anyway, my bedroom TV can handle PAL, SECAM, NTSC and PAL-M (it's a 38cm/15" LCD job from Sharp) but I don't believe my DVD player can (I lost the instructions). And in any case I'd prefer to watch the DVDs on a larger screen.
And I don't believe any of my friends was as stupid as I was in giving myself a LCTV for christmas (which, incidentally, cost as much as a 29" CRT :( ) so their TV's will only handle PAL-M and with a bit of luck, NTSC and PAL-N (Argentina's 25fps version of PAL - see how we South Americans like to complicate things and prevent cheap imports from the US?).
None of us has a DVD burner at home (YET), so I think I'll just ask my friend to bring one or two really rare titles and see how the play here. What should I look foward to? Jumpy or unstable pictures? Artifacts?
Thanks again!
PS. Yes your reply was a bit technical but it's already managed to change the subject of our Yahoo!Group from football to TV/DVD/SNES cart compatibility! :D
Tahrey1043
K... let me think.
As a personal comment, even at the lower resolution and oddly chosen refresh rate (who came up with 60hz mains electricity anyway?) I'd prefer PAL-M over NTSC. It really does make a better job of colour accuracy and all-round sharpness. (I can tell what system a programme's been recorded in sometimes, even when it's the same numerical standard - makes that much of a difference).
If your friend's TV will handle PAL-N, they might be in luck. It's probably exactly the same as PAL-I (the UK/most-of-europe one) just with a slightly different decoding method or range of air frequencies. The actual picture content should work just the same.
As for the DVD player, I can't really say, but there shouldn't be any in the world made that don't support at least reading of PAL(-I/N) standard pictures and putting them out in some kind of understandable manner regardless of their "home" configuration. It wasn't an official standard for VideoCD (just bolted-on for v1.1) but it was there from the beginning for DVD.
Quite how your DVD player responds to it, well, I guess you'll have to wait for the discs to see. Play around with the menus if you haven't already, see what picture options there are. (Heck, even my brother's £50 "VCD/MP3 Walkman" came with a switch). It may automatically switch to the higher rez/slower scan standard, in which case it's up to the TV as to whether it works (see if you can pick up Argentinian stations :D ), or it may transcode the movie, losing a bit of quality and shoving in an 'extra' frame every... uh, five? six?.... about that many times per second too, anyway, such as the maths go.
What to look for:
If the player automatically switches to PAL50 (625 lines) format with regular PAL(-M) encoding, and the TV can handle it - sweet, pure higher-rez, slightly more flickery DVD joy. Cherish it. :D
(I'm hoping my own player will do this in reverse with my mum's older, somewhat larger TV when my American DVDs finally make it across the pond.. not too confident, but we shall see. Seems to have a problem with S-Video and NTSC but if i change it to less faithful Composite.. may work better)
If the player automatically switches to 625/50 with PAL-M but the TV can't handle the different resolution - the picture will "roll" (about 6-10 times/sec) and give you quite a headache. Unwatchable, of course. It may even go to blue-screen, static or switch off. Much like a monitor when you try to set a mode it can't handle.
(Should really be much less of a problem with a TV than a monitor unless it's got rigid circuitry regarding how many lines it can put out and rate, and even more rigid on "overall" picture frequency (lines x pictures).. PAL50 is 15625hz, PAL60/NTSC is 15734hz.. 0.7% difference. Whereas a computer monitor may have to handle from 24khz through to 60khz even for a medium range model)
If for some reason it changes what output standard it uses, regardless of the lines & frequency, and again the TV can't handle it - you may end up with a black and white picture, and it may also seem oddly "dithered" (faint chequerboard of light/dark dots where you might expect to see colour). The black and white signal for both NTSC and PAL standards is almost identical, but the colour is handled in such a vastly different manner that it merely appears as faint interference on top of the black and white if your set isn't compatible.
If the player successfully trans-codes the image from the PAL50 (625) standard to PAL60 (525 lines, essentially NTSC) and puts it out as a native PAL-M signal - can depend on the source. TV shows (50 half-frames of alternate odd/even lines) may suffer more or less than films (25 full unbroken frames) depending on method. At best, it will seem slightly less defined than it would on a regular PAL50 TV (maybe play it before returning to Brasil to see), with no "break up" when things move or scrolls happen on TV shows, and the smoothness of motion will be almost indistinguishable, seeming like real life for all but the quickest, most uniform whole-scene scrolls (it's almost inescapable that there will be some regular (5 times/sec?) and mild "jumping" - it's even just-about noticable on BOTH PAL and NTSC versions of "24", which seems to have been shot on 24fps film and then directly transcoded through a very good smoothing device to both systems (otherwise the PAL one would be "23.5" :D). There's still telltale jumps, but they're so well smoothed out that you don't notice unless your eye has been trained to them on more obvious films.
If it all goes wrong in the transcode department, you may still get a properly sized picture playing at the right speed inside of a regular PAL-M signal, but it will be far less watchable, in 3 ways.
1 - The "jumps" where duplicate frames are inserted 5 times per second (25+5=30) will not be smoothed at all and be quite noticable, scrolling scenes will be very jarring, and it will make things seem a bit anime-like in general (if you're importing "low-speed" animated features you may well not notice anywhere but the scrolls :D).
2 - The line reduction may be done again in a very crude manner (such as both my DVD player and cable box do for fitting 16:9 into 4:3 letterbox - just missing every 4th line completely) where for every 5 lines or so shown, the sixth is cut out without any smoothing, leading to jagged edges on anything that's curved or diagonal in the picture, "shimmery" motion in the vertical directions, and anything that's small detail down to the pixel level will be altered in a bit of a 'mirage' or 'optical illusion' fashion. It's really the most minor of the problems as it's often not noticable if you sit a fair distance from the screen and you get absorbed more into the content than the presentation.
3 - Also if it mucks up the adaption of 50 split pictures (at ~312 lines apiece) into 60 splits (~462) there will be tears at bedtime for any TV show, or film that's got the wrong 'frame order' set (each half of the 'full' 25fps frame meshes into the following one, rather than it's companion - not noticable on a 50hz set, but looks bad even on a 100hz) - seen though "tearing" and other break-up artifacts when things appear to move in a jerky, smeary manner and may even lose lines in the wrong places. It's a bit hard to explain without a picture, but if you suspect it, freeze frame a motion scene and skip through one at a time - see if things that move have "comb" ghost trails to them, particularly if its a comb with the odd tooth missing. Done right it can even be used to cleverly hide the worst of the added frames - but often as not this isnt the case!
Other stuff that I wouldn't much expect to see:
Complete balls up or non-attempts at transcoding. Your film will appear vertically stretch as the top and bottom 50 or so lines go missing. Or the picture will run 20% too fast, maybe even leaving the sound behind (with an option on the pic occasionally pausing to let it catch up, or just skipping the audio forwards every few of seconds), as a 25fps picture gets played at 30fps without any extra frames added. Perhaps both. Worse yet it may end up rolling it in hardware - showing 80% or so of the picture on one frame, then the last 20% of that and 60% of the next, and so on, 5 times per second, just as bad as if the TV was playing up.
Truly bizzare things that you'd be very lucky to see, but my experiments with VCDs have shown me:
Machine just freezing up and having to have the power cord pulled to get it to eject. Very strange picture artifacts such as green/purple blocks appearing all over the place instead of various picture parts, reversed blocks, delayed blocks, motion 'smearing' especially of missing/delayed/green parts (can get *very* ugly), horizontal rolling :!:, very high speed play as player searches for a "properly encoded" part.... etc etc. On my own player, I had to do odd things like making an SVCD (full SV resolution) using vanilla VCD encoding, attempting a max quality "KVCD" (528 horizontal rez SVCD - yep...), very bonkers bit-rates, etc.... all the same, they happened, and are examples of what a confused DVD chipset can do.
I shouldn't expect you to see any of the problems in the last section *at all* with a commercially produced disc (then again, early Matrix DVDs had problems like that!), even a foreign one. Those in the section just before that, also hopefully pretty rare, but could be possible if the makers of your player disobeyed the laid-down orders on DVD standards and only included enough circuitry to put out a basic picture in the country of sale without any "hidden extras". (Annoyingly, this could even be in a fairly expensive machine! EG, Sony is a bugger for leaving out anything but the most basic features - on all their equipment.. still the general quality is good enough that if i don't need those features, i still buy their kit)
Things that you can't really attribute to the player, etc - overcompression and other artifacts like that; blurry, faded picture, noisy soundtrack. That's just sloppy encoding on behalf of the video producers :D
(a final, odd problem I had, though I dont think ANYONE making a commercial disc would replicate it - self encoded long-play VCD... used a 'custom encoding matrix' supposedly designed for Anime to try and reduce the distortion from having to compress it more (117minute film on a 80m disc).. did horrible things to the picture on the DVD player, and brother's VCD player, made it look a bit like a sinclair spectrum game - black and white info still good, but the colour information was reduced to large, flat mosaics, far worse than the 'extra compression' would have been.... bizzarely, I didn't pick up on this until the CD was burnt, as it played *fine* on three different computers... not all MPG decoders are made the same!)
Good luck. Hopefully all this hasn't worried you too much.
If push comes to shove, you can always watch it on the computer and set up a TV-out, if your video card suppports it (and you have a DVDROM). That can be the best way sometimes.
Or spend a while to make your own sup3r-skill0 L33t transcoded VCD of the DVDs (well, you said no DVD writer, but maybe a CD writer?)
Babe RuthLess
Cheers Tahrey - that was a lot of information, I'm still processing some of it! :D
I've got a CD recorder and am going to acquire a video capture card for my PC as part of a plan to convert my recorded TV show collection to digital format. So, if everything goes wrong with these DVDs, I can always use the equipment to make VCDs out of them like you said.
On a separate note, I can tell when something's been originally recorded in PAL50, too - particularly TV reports from Brazilian correspondents in Europe and elsewhere. I don't know quite how to describe the images, perhaps they look a bit hazy when compared to locally-recorded ones.
As for NTSC, I don't know why, but NTSC-encoded video and DVD pictures show their line stucture very clearly even on small-screen TVs (like my bedroom's 38cm) when compared to PAL-M output. I wonder why, when both systems appear to have the same line structure.
In the meantime my friend was instructed to bring me copies of 'Stalingrad' and 'A Pure Formality' plus a few other titles for the other guys. We've all chosen titles that are impossible to find anywhere in the Americas (as far as online stores go) because DVDs cost so much in Europe.
Still, many thanks for your help - I can see you're as keen on video technology as you are on VW Polos!
Cheers,
Carlos
rooboy
Post by rooboy »
Babe RuthLess wrote: On a separate note, I can tell when something's been originally recorded in PAL50, too - particularly TV reports from Brazilian correspondents in Europe and elsewhere. I don't know quite how to describe the images, perhaps they look a bit hazy when compared to locally-recorded ones.
all this is down to the framerate, where Pal-m and NTSC are both 30fps, it is just down to the colour system (NTSC uses one tube for all it's colour, pal uses three: red, green, blue to put it in it's simplest form) so it is relatively easy to convert. European Pal and SECAM (yet another system used in france, some of their ex-terrirtories and some middle east countries) run on 25fps. The blurring occurs because they have to stretch the frame and merge part of it with the next one (the easiest way). We don't really have that problem as we have no choice but to do it properly as it would look stupid.
There is another problem that every single 25fps film dvd will suffer from though. movies are shot at 24fps, so to save money, all the studios do for these markets is speed up the frame rate by one. It is not enough to notice any difference in the pace of the film, but it means that films are roughly 4 minute shorter than in the cinema.
With 30fps markets they cannot do this as it would be noticable being 1/5 faster than before so it has to be formatted, athough most dvd players with a switchable tv output (pal/ntsc) can hande this.
Tahrey1043
babe ruthless wrote: I've got a CD recorder and am going to acquire a video capture card for my PC as part of a plan to convert my recorded TV show collection to digital format. So, if everything goes wrong with these DVDs, I can always use the equipment to make VCDs out of them like you said.
Heh... well... don't go down the route my uncle did, unless your recordings aren't great quality. He got a cheap USB plug-in thing that basically sits as a box between the composite source (in this case, his camcorder, for playing back home movie hi-8 tapes) and the port. I suspect it's USB v1 :( ... the software is awful for one thing, but that's not the major problem, as the picture quality is diabolical :p.... he's trying to make DVDs with it from source material that's pushing SVHS quality (so should look damn good, though not DV quality) and it looks like some of my dodgy VCDs that have come from people wielding ancient VHS-C recorders in an after-hours cinema (...and then transferred to disc using similarly old computers and internal cards).
babe ruthless wrote:On a separate note, I can tell when something's been originally recorded in PAL50, too - particularly TV reports from Brazilian correspondents in Europe and elsewhere. I don't know quite how to describe the images, perhaps they look a bit hazy when compared to locally-recorded ones.
What would you describe the overall watchability of those recordings as, though? Assuming your TV stations have all up-to-date equipment, that's about as good as you could expect a UK DVD to look on your television (top-notch transcoding) unless both the DVD player and the TV switch into 50hz mode.
(( I suspect the haziness comes from having to do a real-time 20% reduction on the number of lines - hard to smooth the "gaps" without causing at least a little blurriness - and, if it's motion-hazy, from over-smoothing the 5-times-a-sec gaps where an extra frame is shoved in. ))
babe ruthless wrote: As for NTSC, I don't know why, but NTSC-encoded video and DVD pictures show their line stucture very clearly even on small-screen TVs (like my bedroom's 38cm) when compared to PAL-M output. I wonder why, when both systems appear to have the same line structure.
I've found NTSC to be clearly more "liney" than PAL too... well, and PAL60 more so than 50, too :) ... probably due to the lower number of lines, but then I would have expected the "beam" to have been set wider in order to cope. After all I rarely see *any* gap between lines with a pal TV signal.
Heck... actually...... I dont know. it may depend on other circumstances. I have PAL50 playstation games (eg, GT2*) that can look similar to this. It's a bit puzzling.
It's a known thing with NTSC however - it's why many console emulators (almost exclusively originating from USA or Japan) include a "simulate scanlines" display option :D
babe ruthless wrote:Still, many thanks for your help - I can see you're as keen on video technology as you are on VW Polos!
Hehe, I was into all this nonsense (even if on a very basic level) before I could even drive, let alone before I made the final coin flip on what first car my 700 hard earned pounds would be wasted on :D
When I had the time for it (i.e. at university when i should have been studying rather than scoring 2 grades below prediction) I could have talked your ears off even worse O_O
rooboy wrote: all this is down to the framerate, where Pal-m and NTSC are both 30fps, it is just down to the colour system (NTSC uses one tube for all it's colour, pal uses three: red, green, blue to put it in it's simplest form) so it is relatively easy to convert.
Without wishing to be rude, rooboy.... "um, come again"?
1. your sentence appears to change subject halfway though - you say it's to do with the framerate and in the same breath change to saying its because of the colour guns.
2. ntsc gets three colours out of one gun? That's a neat trick. please show me how that works. (or conversely: my PAL tv has three tubes? i'm sure i would have noticed by now...) ... and what of the multi-standard TVs, or that awesome (albeit 13 inch) Phillips monitor that came with my Atari in 1989, which could do PAL and NTSC full colour hook ups direct out of the box without need to change tubes - and a few other computer specific standards besides. The tube and projection gun in TVs are pretty much standard worldwide (though the dot-mask may change to adapt to different numbers of lines - if it's not a Trinitron), on single-standard sets the limitation comes with A/ the timing circuits controlling the electromagnets deflecting the triple X-ray beams, B/ the decoder filter circuits which separate out the different information channels (audio, black and white, colour hue and strength) and recombine them in ways the "raw" projection circuits can understand.
I think maybe you've got the connection standards mixed up with the actual TV circuitry. For a quick reference, there are a small number of main ones, and they can actually be applied to either PAL or NTSC...
(beleive it or not the next section is a complete rewrite of what I originally put, half asleep yesterday evening, and about half the length)
RF (radio frequency) - what you get out of an aerial, VHS player, old-style cable decoder. Not very good quality, as all four picture components (black & white, colour hue and strength, synch), audio, are combined on the one signal and then modulated into a radio wave for transmission (competing for space with at least 5 others locally) - whether through the air, or in a wire between your boxes. It's quite amazing that you can get the quality that you do from aerials on modern TVs, with the challenge they are up against!
Composite video - a step up, as it is just the video components are mixed together without audio, and without conversion to radio waves. Gives good enough quality most of the time, with minimal clutter, which is why you see it's little yellow round socket on pretty much everything these days. It can still suffer from dodgy colour accuracy, some smearing and distortion effects e.g. where there's purple bordering green, or a fine chequerboard pattern, but it's usually not a problem unless you're mad about quality or using a lot of 'hard' computer graphics.
Both of the above are used equally across PAL and NTSC, and also show the biggest variation. The composite signal itself has a certain base frequency, for better transmission and easier synch. PAL is somewhere around 4.2 - 4.5mhz (roughly translating to that many pixels of colour information per second and at least twice as much B/W clarity), and the official NTSC specs say 3.5 to 4.2mhz - you can see that at essentially the same line frequency, the NTSC transmissions will have less horizontal clarity, and many stations record and even transmit at lower frequencies than this as the airwaves are more cramped (lower freq = fit more channels in) and the regulations looser. In addition NTSC settled on cheaper AM-type colour encoding (hard to automatically 'tune' the colour, susceptible to interference), whereas PAL uses more robust FM encoding and doesn't normally need a colour 'control' (compare AM radio to FM..)
RF encoding compounds this, as PAL tends to be on UHF bands (low Ghz) allowing a clearer picture over a short distance, whereas NTSC also uses VHF (high hundreds Mhz) for greater range at the cost of clarity. Much like medium wave vs long wave radio.
Higher quality standards include
* S-Video, a rather odd american invention that has spread to europe. Small circular socket with 4 pins, splits the video signal into Black & White with synch, and Colour hue/saturation (well, to be technical - "red" and "blue" components. Don't ask me how THAT works). As it's also a non-broadcast standard, the frequency is fixed at the highest level. May seem like a kooky idea but it works very well, virtually eliminating most of the problems seen with Composite, with almost monitor-like clarity, and only needs a slightly thicker cable rather than several thin ones or a chunky SCART... so much so that component outputs are often not bothered with even on comparitively high-end NTSC kit. Still, the colour resolution is only half of that of the black and white (not a problem with anything except computer/console outputs - DVD has only a half-rez colour clarity itself due to the MPG standard).
* Component video. In NTSC regions this tends to be Y-Cr-Cb (an extension of SVideo, but using separate lines for both colour components - usually three composite-style cables) or Y-U-V (using hue/saturation not red/blue), making for a very short and simple circuit path inside the TV; socket, to picture adjustment (working *directly* on those signals), to RGB decoder, to tube. With PAL, it's often RGB (particularly with consoles and cable smartboxes), utilising the 21 pin SCART standard socket to split off even the synch onto separate wires whilst keeping picture and stereo sound inside one (thick) cable (also capable of composite and s-video!), meaning that theoretically the picture can go straight from 'source' to the colour guns in the tube without encountering any more circuits, for exquisite monitor-class clarity. As it is, it still has to go through the brightness/etc chip, but that is all. Some NTSC equipment also uses RGB (usually through a similar method to Y-Cr-Cb) but it's generally 50" sets and projectors - specialised and highly expensive stuff.
(Really, all three are just variations on the same thing, just moving some conversion stages from one side of the cable to the other).
The colour clarity with these methods is unsurpassed, being 1:1 with the black and white detail. Also the actual base resolution is higher - i've had a sharp and fully usable 720 pixel wide display from an RGB TV-out card, vs about a 560 maximum from composite (where even VGA is a bit blurry). I tried pushing it up to 800, which may have been better but for the actual screen not having a sharp enough physical dot-mask in the tube!
So what I think you're thinking of is - to make a massive assumption....
Composite/RF, maybe SVideo if you didnt realise it was split, for the american TV sets.
Component RGB for the european ones.
rooboy wrote:European Pal and SECAM (yet another system used in france, some of their ex-terrirtories and some middle east countries)
As an aside; my understanding of SECAM is that is essentially the same as PAL, it just handles the colour encoding in a weird way, much like an Amiga in HAL mode. Instead of a pixel having an 'absolute' colour, it instead is described as how different it is from the previous one :shock: Which must make for a lot of fun effects in bad weather!
(most PAL tvs and videos are now SECAM compatible, and vice versa, as they've had a lot more cross exposure to one another)
rooboy wrote: The blurring occurs because they have to stretch the frame and merge part of it with the next one (the easiest way). We don't really have that problem as we have no choice but to do it properly as it would look stupid.
Yep.... even better, to blur the first one of the frame pair that's being doubled with the preceding frame, and the second with the suceeding one. So maybe three or four of every six/seven frames will be "mashed". Of course them being interlaced makes it easier and more complex at the same time - an effect which is hijacked to great effect by NTSC stations for showing films.
("We" being where, and doing things "properly" how? :) ... sorry I dont know where you are!)
rooboy wrote: There is another problem that every single 25fps film dvd will suffer from though. movies are shot at 24fps, so to save money, all the studios do for these markets is speed up the frame rate by one. It is not enough to notice any difference in the pace of the film, but it means that films are roughly 4 minute shorter than in the cinema.
I don't suppose it's a money saving move - it just gives the best quality possible in the easiest fashion. Even if it were more expensive it'd be the preferred method. As it happens it's almost free - it's a piece of cake to tweak the fine speed adjuster on a cine projector so that it will run the film one fps faster - and facing into a TV camera, makes a "telecine" projector. Really, would you notice that a film was 4% faster than it was last time you saw it, unless you had perfect pitch, a stopwatch, or were sitting in the cinema with a portable Televideo? Truth is you probably would never have noticed had you not been told. The difference is (naturally) 1 minute in every 25, and approx one semitone in sound (going up from a white C key to a black C# on a piano), very difficult to tell. I'll take that over a jumpy NTSC telecine'd pic or a hazy, needlessly transcoded PAL version any day.
(plus it means I can fit an 83 minute kids' film onto an 80 minute VCD without having to pull any fancy tricks :D )
rooboy wrote: With 30fps markets they cannot do this as it would be noticable being 1/5 faster than before so it has to be formatted, athough most dvd players with a switchable tv output (pal/ntsc) can hande this.
Yep, instead, you have another, different thing also confusingly called Telecine. In the case of NTSC, it involves lengthening every other frame by half to bring a 24fps picture up to 30fps (the interlacing being finally useful for something - producing a natural blend effect over what was originally a full-frame non interlaced pic).... technically "3-2 Telecine" as one frame runs for 3 interlace "fields", then the next only runs for 2, alternating the field order 6 times a second. Again, it works very well on still scenes, but produces a constant, very small but noticable "jerk" on fast motion, slightly alleviated by only being a half-frame of jigginess at a time. It used to be the case that this was always hard-coded onto the video tape or in the TV transmission, but with DVD, there's the option for the picture to be recorded "progressively" in pure 24fps for the benefit of those with the ability to play it back, with the player doing the telecine in hardware. This happens with too few films, unfortunately, and often a dodgy 30fps hard coded one gets directly transcoded to 25fps PAL without going through the essential Reverse Telecine stage back to 24fps. This is where pain occurs (especially on freeze frame) both picture wise and in confusing the MPG encoder..
(also, it's just a touch more complicated than that - the NTSC standard is actually 29.97fps, or exactly 99.9% of 30fps, for reasons lost to history. So you have to alter the timing of the projector *anyway* by 0.1%, or find some way of hiding the 'dropped' frame you get every 33 seconds without it causing an even more noticable jump)
(* hm, i wonder if the half frame thing gets used for 25-to-30 conversions as well... Something like 3-2-3-2-2 instead of 3-2-3-2..)
In summary, i really like living in a 25fps country when things go right. Though the ultimate would of course be to live in america - so I could get very soon an HD Blue-ray disc player, doing a pure 24.000 frames per second progressive picture, with a 72hz scan rate on a 50" screen :)
What was the question again?
(yay for posts that get written over the course of about 15 hours with looooong breaks... i fell asleep at the keys)
:twisted: :twisted: :roll:
