Fitting rear speakers into a 5 door 1.2s (2002)
I would appreciate any help or websites on fitting rear speakers in my 5 door polo 1.2 s. Thanks in advance.
Do you mean how to get to the speakers?
Or have you got a Beta unit and want to wire in rear speakers?
Getting to the rear speakers can be easy and is a matter of popping off the door handle, unscrewing what’s behind that, and prising the door panel away with your fingers.
I'm not 100% how to do this, but like I have said 100's of times.. buy extra door clips.. you will probably need them!
I *think* the rear speakers may be just screwed in not rivets, but if you do have rivets you can drill them off and replace with normal screws.
However, if you want to wire in speakers you will need a shop to do this unless you can or want to and you need the speaker surrounds (directs sound into the car) you can get these from VW, they're like rubber/plastic
Note: Anything you want to take off in a vw will have torx screws and you'll need a little kit like this:
The surrounds are just things that go around the outside of the speakers so that when the panel goes back on, the sound goes into the car instead of everywhere. ( this is not a good explanation sorry
) But they clip on.
And yeah the clips break easily, always best to have about 15 spare if you can.
Sorry I can't be more help
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
