[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Antifreeze or Coolant type... - UK-POLOS.NET - THE VW Polo Forum
Hi, I bought a 1999 1.4 CL last week and today the engine overheated when out and about. I phoned the AA and the chap replaced the thermostat valve (said it's regular problem). He also drained the coolant in the process, and told me to go into the garage to get some antifreeze - saying any universal one will do. After filling the car back up I went on my way, but when I got home I had a look in the manual and it specifies G12 pink coolant. The AA chap put in a blue antifreeze/water mixture, and I'm a bit concerned if it was the correct type. Does anyone know if this will cause any issues or damage?
Blue is a cheap antifreeze. Pink G12 coolant is very expensive, and thats why garages and the AA tend to avoid using it due to cost. 3L is well over £8
Doubtful you'd have any damage from using 'blue' as opposed to the recommended 'pink' anti-freeze. The only difference I can see is the 'pink' is longer lasting than the 'blue', before it degrades. So as long as you check its strength once a year & top up if necessary, you'll be fine.
Pink is best lol BUT I wouldn't get scared and think the blue one will actually 'damage' the engine! its just that the pink one is of better quality and makes the engine last longer then the other one would!
