Need help guys
polospeed
Need help guys
Post by polospeed »
The rents are getting me some coilovers plus frony and rear strut braces. How do I go about fitting the front strut brace? I might need some help witht the coilvers but will let you knw what set they get me. cheers guys
George Agdgdgwngo
Post by George Agdgdgwngo »
I am assuming it is a front upper brace? If thats the case it will just bolt on between your chassis and the 3 nuts on the strut tops. However, if you are not sure about fitting the brace, are you sure you will be okay setting up the coilovers yourself?
pip_polo
Post by pip_polo »
if you have a deisel its a bit trickier to do strut brace. search for a DIY guide wrote by 'dino'. that is an awsome run through and you cant do it wrong. easy tbh.
