vibrating clutch and whistling heater, worry?
JoeG07
Post by JoeG07 »
My clutch vibreates as im pressing it. also when the fan is on and pointed at my face it whisltes out of the air vent. reckon these are things to worry about?
NOZ
Re: vibrating clutch and whistling heater, worry?
Post by NOZ »
Clutch vibrates OR is it more like a creak whilst you press down?
Its known as a pedal box failure. Basically if you have a hard clutch putting strain on the pedal box, the joint where the clutch pedal fits takes the pain. It starts to twist apart because the weld isn't strong. To eradicate the problem, weld in a metal plate over the weld to strengthen it.
JoeG07
Post by JoeG07 »
its as im bringing the clutch up i feel it vibrating. not like a shuddering, just a vibration. i might get it checked out you reckon?
NOZ
Post by NOZ »
I've never heard anbyone to have vibration issues with the clutch pedal. You better get it checked out incase the problem gets worse.
JoeG07
Post by JoeG07 »
reckon it could just be the vibrations of the engine?
