Got a New Toy!!!
freshblood
Re: Got a New Toy!!!
got to admit i thought you were younger aswell timturns out your older than i am
Happy 21st
Happy 21st
Happy belated birthday tim!
Looks a fair bit of kit that
Any links to it, iv always been intending on getting myself one! Makes the wash process slightly less un-nerving so your not dragging dirt along your bodywork!
Mouse order a new connector for it ... mines really stiff too
& I need a replacement to sort it.
Tim - what PW you got?
- Tim_GTi
- Post Whore
Cheers Phil
Here's the link:
http://www.elitecarcare.co.uk/elite-hea ... 04f84293a1
I've got a Powertec PS2000 mate, unknown PW, but does the job fine. It uses an Kew/altor connector.
I have just ordered one of these, what foam are you using tim?
- Tim_GTi
- Post Whore
Just the standard elitecarcare foam your given with it for now mate.chewy wrote:I have just ordered one of these, what foam are you using tim?
Are you getting a nice good thick foam with it? I ordered a bottle of maxi suds 2. Also Meguiars Hyper wash is ment to be the muts nuts
- Tim_GTi
- Post Whore
Yes it's really good, there's probably better stuff out there, but I haven't had any experience with any other type so can't comparechewy wrote:Are you getting a nice good thick foam with it? I ordered a bottle of maxi suds 2. Also Meguiars Hyper wash is ment to be the muts nuts
When it turns up I will be like a kid in a swwet shop, will be washing cars as they drive past my house lol
- Tim_GTi
- Post Whore
Aye mate, it;s relaly fun.
Here's mine after a few mintues to soak.
It's quite hard to picture because you've got to soak it, put it down, turn off the PW, turn off the hose, run inside, setup the camera and get a good pic!
By the time all that's done, it's dripping away.
Just used mine today for the first time. Wow cant believe how thick the foam is. Filled the bottle with about 1cm of maxi suds 2 and 1cm of snow foam then filled it to the top with warm water. I covered the car 3 times and only used a 3rd of the bottle. And the g/f likes it because the maxi suds smells of marzipan.
- Tim_GTi
- Post Whore
Recommended products then? If so I'll try some maxi suds out
