HELP my polo keeps hold the revs when stopping
polo6ndub
Post by polo6ndub »
my brother was fixing my heater on my car(Polo 6N 1998)
then decided to clean out the throttle body :)
he done a reali good job until :x i drove it the next day
what it keeps doing is when the car heats up and im driving
if im coming to a stop with the car out of gear the car holds the revs until the wheels stop moving sometimes increases the revs then goes back to idling at 1000 revs.
i have put the car on the laptop and no falts are cuming up and tryed resetting the throttle alignment still no luck any idea's
PLZ HELP
polo-sib
Re: HELP my polo keeps hold the revs when stopping
Post by polo-sib »
Think the throttle body needs a reset using vag-com as I tried the battery trick in the past a few times and its never worked.
polo6ndub
Post by polo6ndub »
Do u kno or any1 else kno the details on how to reset the throttle body on vag-com just in case my brother is doing it rong :D
alexperkins
Site Admin
Post by alexperkins »
polo6ndub
Post by polo6ndub »
Thanx polo-sib & alex im guna give it a go later 2day
NOZ
Post by NOZ »
Will resetting the ECU help?
I'm not technically minded with this but the ECU was reading a different setting before (ie with all the dirt in the TB), maybe the fact it's changed is making the ECU think the TB's like before.
polo6ndub
Post by polo6ndub »
u'v got a point
cuz i have resetted the throttle body and vag-com says its all ok but it still doing the same thing
there is 1 thing i hav noticed it will only have this problem when the engine heats up not when the engine is cold :?
polo-sib
Post by polo-sib »
polo6ndub wrote:u'v got a point
Pure guess lambda as you run rich whilst it heats up, once heated you run normally... but its a pure guess where thats got covered in gunk when the tb was cleaned, again a pure guess.
Another idea is when cleaning tb you got stuff in the hoses such as oxygen or vacuum tube, again a guess.
polo6ndub
Post by polo6ndub »
just to let evry 1 know iv solved this problem after sending it to vw and them telling me to change the throttle body and they wanted to charge me £400 to do this
they wernt 100% sure it would solve the problem so i told them sod it
my bro was trying to fix it and it ended up being the COOLANT TEMP SENDER
TOTAL COST £15 from europarts :lol: :lol:
NOZ
Post by NOZ »
Lol can't believe I didn't think of that!!!!
The temp senders one of the nmost common faults on 6n polo's when it comes to rev issues! :roll: Atleast you sorted it already and bet your lucky you didn't get bent over by VW!
polo6ndub
Post by polo6ndub »
yhh im happy my car in on the up
i done my first service by my self a few weeks ago so its running nice im guna get the clutch changed the she will be running perfect lol
thanx again for your replies
