The VAG-COM report looks like this:
Anyone have any idea what the engine codes relate to and why they have come up?VAG-COM Version: Release 409.1-US
Chassis Type: 6N - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01: Engine
Controller: 036 906 033 D
Component: 1.6l/4V SIMOS3 00HS3512
Coding: 00031
Shop #: WSC 00788
WVWZZZ6NZ1Y350568 VWZ1Z0A1574895
4 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 6X0 907 379 C
Component: ABS/EDS 30 IE CAN V004
Coding: 05603
Shop #: WSC 00788
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
16-10 - Signal Outside Specifications - Intermittent
Address 08: Auto HVAC
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 04001
Shop #: WSC 00788
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6N0 920 904 K
Component: KOMBIINSTRUMENT BOO V13
Coding: 00444
Shop #: WSC 00439
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN
Coding: 00022
Shop #: WSC 00000
Address 25: Immobilizer
Controller: 6X0 953 257
Component: IMMO 0008
Coding: 00001
Shop #: WSC 00000
Address 45: Inter. Monitor
Controller: 6N0 951 171 C
Component: Innenraumueberw. 0003
Address 46: Central Conv.
Controller: 6N0 959 799 B
Component: 8U Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00788
Address 55: Xenon Range
Controller: 6N0 941 273
Component: Leuchtweiteregelung 0001
Coding: 00002
Shop #: WSC 00788
End --------------------------------------------------------------------------------------------------
(I replaced a faulty water temp probe a few months ago.. so I assume that error log was from then, rather than a recent one)
I have cleared them.. but I imagine they will return...
And...anyone care to hazard a guess what any of the others relate to?
Really worried about the engine... I am about to do a cambelt...and might as well do anything else thats needed whilst its appart...
