[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 TT pedals? - UK-POLOS.NET - THE VW Polo Forum
best place nowadays (after vagparts closed:() would be the dealers or eBay. Or maybe volksparts. Brake and clutch should squeeze on, and you need the LHD accelerator pedal, which should need some adhesive such as Araldite.
floaty wrote:Could you not order ali pedals off the polo dune from the dealers?
They're probably the same ones, VW use them on a few newer models.
Darren, I think they fit 6Ns, PM me a pic of your pedals and i can tell you if they're the same or not. You need the LHD accelerator because the RHD one is a completely different shape, it's too small.
