central locking pumps
sharpspark
Post by sharpspark »
central locking pumps gone in my 6n2.
Which pumps will fit it from other cars? Cheers
kraized
Post by kraized »
Not sure about other cars but make sure you can get the same part no as yours if possible and also make sure the PIN allocation on the pump is the same. If yours is 8, a 12-pin pump won't work. My pump recently died and was a bit of pain trying to find a correct one. Try ebay or a breakers yard but avoid VW as they around £200 plus VAT plus labour.
charliec125
Re: central locking pumps
Post by charliec125 »
part number for the 6n2 is -6N0 962 257 A
from a breakers they about £45
its just in your boot so they are easy enough to swap over
