Black diamond drilled and grooved disk all around pads!
Trottagti
Post by Trottagti »
330 quid as mine are 95% worn all around lol!
Went all out without goin to 4 pots, Dont need 4 pots on this beasty, think these breaks will be abit better than mine now lol!
Got the preditor ft pads aswell!
Any1 else have this combo on there gti?
Mouse_GTI
Re: Black diamond drilled and grooved disk all around pads!
Post by Mouse_GTI »
I've got the drilled and grooved disks up front with the predator pads. Made absolute no difference to my braking :(
chris-gti
Post by chris-gti »
i like to here about these but mouse if your looking to change get yourself some good discs and Pagid fast road pads what ive got and i can now out stop my friend who has 4 pots on his stripped out 106 gti :twisted: they have got to be good ay !!
Si_GTi
Moderator
Post by Si_GTi »
I've got the Black Diamond Predator brake pads fitted to the standard OEM discs. I rate them very highly! Almost no brake dust :wink:
SeanGTI
Post by SeanGTI »
i have 280mm drilled black diamonds with the ft pads and i rate them well rears are still standard my discs and pads up front cost me i think 170 which i thought was cheap
Trottagti
Post by Trottagti »
Yeah iv gone for the 256mm drilled and grooved all around cos well i needed new ones all around so fort i better upgrade as my country road drive home is immense lol! Changed to normal preditor pads now as the ft pads only work well when hot, No need for them on road goin brakes as they dont run up to optimmum temp!
Would it be best to change the brake fluid and all that aswell u rekon?
SeanGTI
Post by SeanGTI »
my 280mm carriers only cost me £30 and they needed changing anyway so i upgraded and the ft pads work just as well cold the only difference is they withstand fade upto a lot higher temps than normal i did some research before i got them as i didnt want brakes that didnt work when cold lol i would suggest changing your brake fluid if it hasnt been done for a while (factory reccomended every 2yrs) or if its simple and cheap enough for you to do yourself no point paying loads for it to be done im sure you wont notice any difference unless you have air in the system
Tim_GTi
Post Whore
Post by Tim_GTi »
Yeh if it wasn't changed last service, change it. Every two years is my current bench mark.
Trottagti
Post by Trottagti »
Yeah not sure if its been done since iv owned it but il have it done as it will help a little! Cant wait to get em on i so need breaks there all craped up n like rusty!
Good thing with these disks and pads, No dust in the horrid little alloy recess! Woop woop!
