Digifant Fault code reader
Gareth_GT_Hatch
- Platinum Member
Ok so Ive made one of these as per the instructions on the polo-gt website. And (like everyone said) it doesnt work. I decided to put in an extra resistor on the LED to protect it as optima21 was saying he blew his LED straight away. I was just wondering (and I know its a long shot) if anyone has had any sucess with this for their polo. I get the feeling that the instructions on the polo gt website are for a golf. Theres a wire missed out on the diagram (one of the "signal" wires. Any idea where this goes?
Please help of you can!
Gareth
Gareth
Tahrey1043
- Location: Birmingham! Enjoys: The pseudo-G-Smiles provided by a 1.6 Megane Sport valver...
mebbe a buzzer or a normal light (torch) bulb would do you better? LEDs are designed for like 1.5v, 3v max sort of voltage. I remember having to attach relatively heavy resistors to them for a school project involving a 9v battery (and the sci lab's power supplies could zap them at maybe 6v or less). Dont know what the ECU puts out but it could be anything from 5v (borderline) up to 12v (death!) probably with a fair current attached.
good luck
good luck
hardhitter
- Moderator
Gareth_GT_Hatch
- Platinum Member
amstrange1
Gareth_GT_Hatch
- Platinum Member
Gareth_GT_Hatch
- Platinum Member
I give up. Its a load of crap. Alan gibson's got alot of explaining to do...
Im gonna swap the lambda over with the one on the blue car I think to see If that makes any difference. Easyer said than done though. Does anyone know if I can disconnect it fron somewhere on the loom and where this connection is likely to be. I know where the earth is but I canne see where the other 2 wires go
Gareth
Gareth
hardhitter
- Moderator
Gareth_GT_Hatch
- Platinum Member
Gareth_GT_Hatch
- Platinum Member
Right, been doing more testing. Had a look at the lambda probe connector on the side of the inlet manifold. Unplugged it and found what looked like a piece of clear resin covering one of the pins. How it got there I will never know. Connected everything back up and installed a test wire on the signal wire on the lambda probe. I then used a multimeter (after disconnecting the battery and leaving it off for a few mins) to check the voltage from the probe. At first it fluctuated from between about 0 and 1v like the faq on club polo says it should. It was also idleing alot slower (but still too fast) at about 1100. So I let it warm up and then disconnected the plug from my new blue temp sensor. Revs dropped to about 950 (apparently this is bad as revs should rise in diagnostic mode apparently) Reconnected it and revs returned to 1100 ish. Couple of minutes later the revs went high again 1500-1750ish and I checked the voltage and it was contstant at 0.93 volts. It did change when I revved it but it always settled on this value. Is this just telling me that my mixture is far far far too rich or would someone say its knackered?
Gareth_GT_Hatch
- Platinum Member
Its a proper lemon im afraid. whatever it is it isnt obvious. Ive got to run some comparison tests on the blue car to see what kind of figures the lambda puts out. Its proper fooked the engine though - sounds like a diesel now and the tappits are well noisy. But goes well enough, easily as fast as the blue one. I might have to do that engine swap sooner than I thought...
hardhitter
- Moderator
amstrange1
