Do Gti Windows have Comfort Function?
neilw
Post by neilw »
I'm going to be replacing my Window Reg, does it have a comfort function?
If so what does the comfort function do?
WINDOW REG WITH MOTOR NSF VW 2DR POLO 11/99-10/01 COMFORT FUNC LHF 2Dr Regulator £149.99
WINDOW REG W/OUT MOTOR NSF POLO 95-02 2DOOR LHF 2Dr Regulator £59.99
adam_0612
Re: Do Gti Windows have Comfort Function?
Post by adam_0612 »
by comfort function do you mean if u like flick the switch the window goes the whole way down, instead of having to hold the switch down??
alexperkins
Site Admin
Post by alexperkins »
Do you need a whole reg? If its only the window that wont lift, its just a new motor that you need.
Any 3 door or 5 door window motor will work - its just a case of switching the regs over (easy task) and itll cost far less as you can use a scrappy part.
neilw
Post by neilw »
Cheers Alex,
I've not taken the door card off yet too see what I'm dealing with. You can hear the relays click in when you press the buttons, but the window doesn't move.
There is a rattle form within the passenger door with could be related.
I think the comfort function may be where you can close the windows from the key fob, but I'm still not sure
alexperkins
Site Admin
comfort is for rollup. all window motors have this functionality .
that sounds like a shot motor
if you need a hand im not too far away :)
neilw
Post by neilw »
Cheers for the offer. I'm pretty sure I'll be able to get it sorted. May take the door panel off tonight if I get time.
