I'm just getting the bits together for doing a rear brake conversion and was wondering what size the GTi 6n2 rear discs are?
Also I'd welcome some recommendations on what brand to choose.
Many thanks
GTi brake rear brake disc size?
Re: GTi brake rear brake disc size?
The rear discs are 226mm I think. Thats what Autocar's road test write up has got listed anyway. I can't get at the VW brochure quickly!
I have stuck to standard OE discs all round but am using black diamond "predator" brake pads.
Si_GTi wrote:The rear discs are 226mm I think. Thats what Autocar's road test write up has got listed anyway. I can't get at the VW brochure quickly!
Hi Si,
That's where I'm getting confused some say the rear discs are 226mm and some say 232mm
I don't know either way as I just bought the set up without the discs.
I've found that EBC list them as 232mm for rear discs and Black Diamond say they are 226mm rear discs
Can anyone shed some light as to which size is correct.
- Tim_GTi
- Post Whore
They're 232mm IIRC!
I'm using green stuff pads and drilled and grooved discs, definitely recommend
- Trottagti
Its all about the drilled and grooved these days, My black diamonds are 226m
