Also dont you guys think a sticky is in order for things such as this...gearbox oil spec and recommendations/engine oil spec and recomendations/Brake fuild recommendations/Pads&Discs spec and recommendations/Part numbers for regular service parts, oil filter/air filter/fuel filter/pollen filter etc... I just think it would be extremely helpful to all Gti owners new and old
Gearbox Oil?
- chrischap2003
Gearbox Oil?
Hey guys, Ive had the usual link through the linkage problem. Ive purchased the seal and i am thinking a gearbox oil change is in order too. What would you recommend guys? apparently a 75w90 is the recommended, but what brand would you go with?
Re: Gearbox Oil?
i replaced mine with the standard oil from vw
Re: Gearbox Oil?
I've just put 2.7L of Castrol TAF-X Synthetic gear oil in mine.
Heres what I used at my last service
Engine oil - Castrol Edge 5W-30
Brake Fluid - Any old DOT4 I think I got CarLube
Brake Pads - EBC Green Stuff
Brake Discs - EBC standard Discs
Oil filter - Mann Filter from GFS (£2.60)
Most service stuff can be got from GFS or Eurocarparts. Only really unuseal stuff I have to goto the Dealer for
Re: Gearbox Oil?
Before I ask this...I'm sorry for being so s**t with cars...
Where the engine would I be able to change the gearbox oil?
What symptoms are common with this type of failure (going through some problems with mine)
- chrischap2003
Re: Gearbox Oil?
Aries, generally gearbox oil should last the lifetime in the car. Polo's seem to have a problematic box hence why i asked...Generally the selector seal causes oil leaking from the box (which is located at the rear of the box). Best way to check is get youe head under and have a look , or check for obvious oil stains where you park
Ive just changed the oil in a 1.4 SE and the drain was located on the right side of the box (17mm hex) and the fill was located on the front side of the box (identical 17mm hex)
- chrischap2003
Re: Gearbox Oil?
Am i right in saying Castrol TAF-X is 75w90 fully synthetic?
Re: Gearbox Oil?
Thanks for that, don't think it's my problem then, no oil where I park.chrischap2003 wrote:Aries, generally gearbox oil should last the lifetime in the car. Polo's seem to have a problematic box hence why i asked...Generally the selector seal causes oil leaking from the box (which is located at the rear of the box). Best way to check is get youe head under and have a look , or check for obvious oil stains where you park
- Tim_GTi
- Post Whore
Re: Gearbox Oil?
There's tonnes of threads with recommended oil and discs and pads. All other filters etc are just a phone call away from GSF.chrischap2003 wrote:
